1 - 4 of 4 Posts
Running lights come on, but when I try to use the turn signals it just turns off & the opposite side stays lit? I am also running an integrated LED tail light and have installed the HD relay behind the headlight... any ideas? Here's my Grom, just got it a few days ago :big smile:
Motorcycle Vehicle Motor vehicle Automotive tire Tire
I had same issue. if you have one of those integrated tail lights check your wiring diagram. the wires on the chinese ones are different colors. green is hot red is ground. weird crap like that so get out your test light and get ready to rewire stuff before you just ASSume it's just bad.
I bought an LED flasher on eBay and it sucked. Same problem, after signaling a light would just stick on. Bought a flasher from Napa and it works perfect!
1 - 4 of 4 Posts
