Here's a simple flasher relay that will work for any combination of LED and incandescent bulbs WITHOUT the need for resistors.
This one is a direct plug in, but you lose the clicking sound:
CF12ANL-01 LED Bulb Electronic Flasher | Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs
I elected to use this one that clicks, but requires installing a ground wire to the E pin:
CF13JL-02 LED Bulb Electronic Flasher | Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs
I confirmed this works on my stock flashers and also on a friend's who's running half LED, half stock. But this will work with virtually any setup. The new relay is tie wrapped in place as shown. The yellow wire taps into the green ground wire on the headlight connector and connects to the E pin of the relay. Hope this helps.
