21 - 34 of 34 Posts
He had prototypes in a koso arm, but recently said he would not just sell the roller wheels because the offset was different if installed on a koso or other arm. Koso already provides ashim washer to avoid the horrors of a misaligned chain and tensioner arm.
Going to make sure the bolt holding the wheel has some thread lock on it before install.
Things that worry me.... A bearing failure, while unlikely, can be catastrophic.
The bushing approach eliminates that issue at the cost of a drop more friction.
Discussion Starter · #23 ·
Definitely a drop of Loctite on the threads for piece of mind.
Discussion Starter · #27 · (Edited)
Appreciate the info, been waiting to install mine til I get the 4th bearing support modified (was given one for OG, have to get turned down on a lathe to fit SF) so I can do it all at he same time "while I am in there".... Love that the snap ring gives the ability to change out the bearing as needed.
Looking at the sprockets, I think I may go over them with a wire wheel to smooth out the rough edges before installing also.
That's unfortunate, but just for added perspective, mine arrived perfect and I haven't heard any complaints from the multitude of members in my group who've bought one. I've had JC ports heads for me also, and they've been great as well.
You'll get faster revs out of your motor with a lightened flywheel, but the reason for me purchasing one was to help avoid shearing the woodruff key in my crank, which happens on motors that make power.
Received the JC lightened flywheel today, so hope to get the new speed shop tensioner installed this week with new flywheel.
It came very clean. No complaints.
Will report back!
Installed the speed shop unit.
The Takegawa unit that came out actually seems perfect. No significant wear. I like the beefiness of the Takegawa arm and the weep hole for lubrication of the bushing at the pivot.
The speed shop unit has the advantage of ball bearing metal wheels, if in fact that will increase reliability. Time will tell.
I set tension of the cam chain using the manual tensioner till finger tight and then backed of 1/4 turn. Chain is snug. Finger tight is actually misleading. I gently turn in the adjuster until I feel slack taken out, not until max finger strength, certainly not max wrist strength. Then, I back out 1/4 turn. I confirm that the chain has slack but is snug enough not to jump the sprocket.
"WHAT PART OF "FINGER TIGHT" DO SOME PEOPLE NOT UNDERSTAND?
The object is to take only the slack out of the cam chains, not put any tension on them. It is worse yet if you start to bog the engine at idle. That is damaging tight. The goal here isn't just to have everything silent, it is to know when you have proper cam drive adjustment. It can be silent, but be way too tight.
Fact is it would be better to have a tiny bit of play than too tight. Finger tightening is plenty adequate in every case I've encountered including tens of thousands of miles on my own bikes. I don't care who's manual tensioner you are running, finger tight is finger tight and is adequate to do what is necessary. Any thing more just promotes premature wear or possible head damage. You wouldn't overtighten your drive chain, why would you do it on your cam drive chain?
I have had a few people who bought tensioner kits from me have noise issues when they overtighten the adjusters. Once I get them to readjust them to finger tight the noise may go away or they found it was coming from another source. With around 400 tensioners around the world, I have yet to have anyone have any problems when adjusting them finger tight. The only issues are when they don't follow instructions.
Take this in the spirit it is meant - to open some riders' eyes to the correct adjustment to keep their bikes running. Nothing more and nothing less."
Started up and runs fine. Full test to follow.
Automotive tire Motor vehicle Automotive fuel system Automotive lighting Automotive design
Motor vehicle Automotive tire Rim Auto part Automotive design
Light Automotive tire Household hardware Tool Wheel
Black Household hardware Auto part Tool Electric blue
Tire Wheel Crankset Automotive tire Gear
Discussion Starter · #31 ·
Good stuff! How much weight was shaved off that flywheel? Notice a quicker rev from it? I noticed immediately the difference in how quick mine revved from the Takegawa light weight spinner.
.6 pounds lighter.
Did not take the bike out for a proper ride yet, so no observations to report on performance. Will ride today or tomorrow, I hope!
First ride. 70 miles of hard twisty fun.
Subtle but definitely feel the reduced (25% reduced) mass on the crank mostly when downshifting. The RPMs drop faster. Not as noticeable when getting on the gas.
Makes riding in traffic more difficult as the throttle has to be managed a bit more carefully.
Recommended if you ride mostly WOT.
No idea if the cam guide wheels do anything for performance :)
Part of today's test ride.
Lightweight flywheel has other effects on the bike as well.
The flywheel acts like a gyro, as do the wheels. They all rotate in the same direction, so the combined gyroscopic stability of all three forces affect handling.
Carbon wheels and a light flywheel with spinner delete is one maneuverable Grom!
Read this. Fascinating stuff:
21 - 34 of 34 Posts
