1 - 1 of 1 Posts
Evotech Performance has designed and manufactured a Grom tail tidy that looks incredible on the motorcycle. The innovative design team removed the standard swingarm number plate mount and replaced it with this! The tail tidy is manufactured with lightweight, aircraft-grade aluminum, then powder coated in black for longevity. No modification of your Grom is required when fitting the tail tidy. They even supply a new loom connector for the replacement rear light, so all you have to do is plug it in. All required fixings are supplied in the kit.
Check out the Evotech Performance Tail Tidy here for the 2014-2015 Grom!
1 - 1 of 1 Posts
