21 - 24 of 24 Posts
Discussion Starter #22
what is your idle rpm set to? If it is low - like under 1500-1600rpm, it'll feel like it wants to stall sometimes.
No idea, bike has no rev counter.
It runs high compared to my shadow, and then falls low to the point of stalling and then suddenly jumps back up.
Doesn't do it all the time but most stops it will.
Try adjusting the idle a bit higher and see if that smooths it out. These motors are so small, there isn't as much rotating mass to keep the motor running smooth when it spins too slow.
Discussion Starter #24
Ok so update.
I decided to change the oil, clean the injectors with compressed air, reset all sensors.
Removed battery and charged it over night to make sure it was tip top.
Reset the Efie back to 0.225 mV.
Reset air mix screw too 2 turns out.
And low and behold she is running fine again.
Odd as it's exactly the same setup it was when the problem started, and all the resetting and cleaning stuffs I had already tried before too.
But hey, if she is working again ......
Though I find I am focusing on the idle like a teenager on tits at traffic lights haha
21 - 24 of 24 Posts
