1 - 5 of 5 Posts
EBC Has finaly released OEM replacement rotors.
For those of us who have done the awesome BREMBO Caliper upgrade... finding a replacement Rotor has not been easy.
EBC's New Rotors are same physical dimensions as STOCK, They are just using better metal material. So, you will get a little more friction and braking performance over a stock rotor.
And because they have the same "Pad Surface Area" ..... you can use them with BREMBO Caliper Upgrade Kit.
Starting at only - $43 ..... It's not to hard on the wallet either.
Click here for more details >> Grom Parts Catalog <<
Because, they are same Dimensions as stock, the weight is nearly identical.
1 - 5 of 5 Posts
