Now that I have the Ohlins rear shocks, I could really feel how crappy the forks were. Not afraid to try something new, so I ordered the new YSS fork upgrade kit for the monkey. From Zeedparts, the kit is 202USD, which is significantly cheaper than the Racingbros and even cheaper than the Ohlins. When you consider that the YSS kit includes fork oil in the kit, you can't beat it for value for money.
You don't get 2 sets of springs like you would in the Ohlins, so you have to order the kit with the appropriate springs for your weight. I got mine with 6N/mm springs, which is the recommended rate for 90-110kg riders. The damping circuit looks very similar to the Ohlins kit. One difference that I did note was that there is no spacer/bushing at the bottom of the fork like there is in the Ohlins kit, so I suspect that the YSS springs are longer and actually the right length for this bike.
It's a night and day difference to the bike once it's installed. No more diving under braking and no more blowing through the stroke when landing jumps. I'd definitely recommend this kit to anyone who doesn't care much for the full adjustability of the RacingBros.
The other thing I did notice during installation was just how dodgy the forks are out of the factory. The issues I found during my disassembly were:
- One fork had damaged/missing chroming under the axle clamp/cap
- One fork had practically no loctite on the axle clamp/cap
- Fork legs had 170mL each of some really runny oil
- The holes used to clamp the fork were not drilled properly, so the fork holding tools couldn't clamp properly
- Stock springs were different lengths between the 2 fork legs. One had an extra winding in length.
- The damper piston rings were both in the rebound position out of the factory, so I had no compression damping leg, and 2 rebound damper legs. All fork kits on the market specify that the piston rings should face one in each direction for compression in one leg and rebound in the other
