1 - 11 of 11 Posts
I got out in the garage and disassembled the HUGE diving board on the back of the Grom this evening. I created a temporary/permanent FEL and figured that others may want to do the same.
Here are a few pictures that may or may help you figure it out. :wink:
KEEP IN MIND... I have not yet installed a white light, or turn signals, but will be doing so in the near future.
After getting all of the original fender I flipped my inspection bracket over and re-attached my plate to the lower holes.
Technology Electronic device Subcompact car
Technology Auto part Vehicle
Vehicle registration plate Automotive exterior Auto part Automotive lighting Bumper
Marked the bend lines I wanted
Machine
Machine
Bent both tabs to the angle I wanted
Electronics Auto part Engine Technology
I used the back two bolt holes from the factory fender for my bolt holes and marked my plate where I wanted to drill my holes. Then it is as simple as drilling them, and bolting it together. Remember to use lock washers or in my case flat washers (off of the lower bracket on original fender) and nylock nuts.
Auto part
Auto part Vehicle Automotive exterior Car Automotive design
Automotive exterior Bumper Auto part Machine Metal
Land vehicle Vehicle Motorcycle Car Motor vehicle
This is the finished product which I think turned out great for not to supply anything except 2 phillips head screws, and nuts.
VIOLA!!! a $.23 Fender eliminator kit.
NOTE: you will have to upgrade you signal flasher if you don't reattach your factory signals. I believe there is a thread on it somewhere. I will also update this with my remedy of adding signals and a white light for keeping the plate illuminated... as soon as I have time and the parts on hand.
Ah the DIY method. Much better than dropping $$$ on some of the other offerings.
Next version needs turn signal mount "ears."
Rant: Why in the hell does a manufacturer stress weight savings and then mass produce this very piece from stainless?
Discussion Starter · #4 ·
I would have bought one if needed, but 1/2 the fun was tearing it apart and figuring out how to make something from nothing. :)
LOL... it is aluminum I believe. I am thinking about going with a different style blinker that won't need ears so I won't have clearance issues on the exhaust... Probably just a small LED strip on each side and a single white LED for the license plate light to keep it legal.
What size are the bolts so I know what size washers to get
I was going to do something like this on mine. But then I decided to wait and buy one of those 007 license plate hide kits
P.S. thanks for the pics, now after looking at it I might still have to make this so that I have something there to mount the kit to. Thanks :)
That looks pretty slick. Past experience tells me there is a good chance that it will vibrate a bit so watch for stress cracks down the line.
A few things to keep in mind with that:
obviously it screams pull me over
I'm not sure about the grom but when I had a similarly flush setup on my ninja, the plate was still completely visible after you got about 5ft away from the bike. So if you were going for a hidden plate, it may not be totally hidden unless you give it room to go parallel to the ground rather than flush with the tail. Just didn't want you to go spending $100+ only to find out that your plate is still fully visible.
Sent from my iPod touch using HondaGrom.net
Sorry to beat an old thread up. But by doing it this way. Did the water coming up off the tire through the holes where the old block off plate was ever cause any issues. Made mine the same way as you. But all those holes in the bottom and water getting shot up in there. Wanted to know if you ever covered the holes or ran into any issues
Thanks
If you're worried about water, just put some silicon / caulk on them or you could even close them with a glue gun.
1 - 11 of 11 Posts
