1 - 1 of 1 Posts
Bought the HD replacement Rods from Japanwebike.net a while back in June 2019 when they had a summer sale.
86599
Did some alignment of the oil flow thru holes
86600
Check for proper gap between the bearing and crank
86601
Had to DIY "Red Neck" some tools to press in the bearings and cam sprocket
86602
one done
86603
two done
86604
reason rod need replacement, failed 4v takegawa cast piston failure causing metal parts to go between the piston pin and rod pin hole
86605
second failed rod
86606
1 - 1 of 1 Posts
