1 - 3 of 3 Posts
86617
86618
So I did a wheelie, and you know what happened next. Sadly I broke the rear set and flywheel cover, BUT as I was draining the oil, I tightened the bolt a little too much and cracked a piece of the engine.Do you guys think the engine is done for? Or can I somehow repair it? Will get a picture of it when I get back!
You can probably drill the crack out a but to expand it and fill it with JB Weld.
I did that on a previous Grom where I cracked the case with the cam chain tensioner screw and it was fine.
Sent from my PH-1 using Tapatalk
If you are worried about the crank case you can buy either the right side case or the left side case.
good luck
1 - 3 of 3 Posts
