1 - 7 of 7 Posts
Condensation on my oem exhaust comes out/drips at slip on joint, how about yours. Idles at 1.5 to 1.75rpm.
Completely normal for any exhaust.
Exhaust heats up. When exhaust cools down the moisture that was in a gaseous state condenses and turns back into liquid water. It settles in the low points of the exhaust and then forced out when restarted. At least the moisture before the exhaust gets hot again turning the moisture back into steam. Water is a normal byproduct of any combustion.
Thanks! I am pretty familiar that condensation is normal just never seen it going out of joints before always been from the tip of exhaust. You have a point about the lowest point that I never thought about and I almost put a gasket seal :)
Rusty trail there too.
Stick your finger in the exhaust while its running. It'll blow that crap out the weep hole above the slip joint.
Mine was pouring water all over the place today. Apparently when I ride slowly the exhaust gets cold enough to condense even at the end of a long ride. Thanks for the tip on covering the main pipe to blow the water out.
Here's a pic of the hole with water coming out
Auto part Exhaust system Muffler Pipe Vehicle
1 - 7 of 7 Posts
