1 - 12 of 12 Posts
as mentioned, you may need an electronic flasher. even though you are still running incandescent up front, the load reduction from the LED at back might be enough to not trigger the OEM flasher.
as for connections, i wired the turn signal positives to the oem connections. no need for ground as it's shared by the main connection.
1 - 12 of 12 Posts
