1 - 6 of 6 Posts
Bump - because I can't figure it out
All I can offer is what's in the owner's manual: "If it comes on when the engine is running: ...you may have a serious problem with the PGM-FI. Reduce speed and have your vehicle inspected by your dealer as soon as possible".
Not much help I guess, and you probably have already read this in the owner's manual, so...
what have you done to the bike to cause it?
undo it and reset the ecu.
The bike is stretched, on air with a fender delete.
It did have the tip sensor deleted with the fender delete which left a check engine light on but it didn’t flash.
It just began flashing the 5 long blinks followed by 4 shorts.
1 - 6 of 6 Posts
