1 - 1 of 1 Posts
Back again to share my cheap inexpensive tidy tail that just finished tonight. Will try to demonstrate in details everything I did so if you choose do it, you wont have any surprises and problem.
First started with an adjustable angle fender delete bracket off ebay $12.99. Bracket was meant for a Kawasaki Ninja so modifications had to be made obviously.
Kawasaki Fender Eliminator License Plate Bracket Ninja ZX 6 10 14 R Z 750 1000 R | eBay
Started drilling some holes on the bracket to fit the Grom under the seat.
Gun Firearm Trigger Air gun Airsoft
Automotive exterior Bumper Auto part Vehicle Car
Next drilled out the sides even bigger to be able to use the stock rear blinkers with the tidy tail.
Headphones Audio equipment Headset Gadget Electronic device
Land vehicle Vehicle Motor vehicle Motorcycle Motorcycle accessories
Finished well not quite. Still need to bolt up the license plate with bolts instead of using zipties and some lights for the license plate. Shortly after realizing how hideous the blinkers looked, I decided to change them out asap.
MMMMMMMM much better looking blinkers and a lot smaller. Blinkers were +-$20 at my local Cycle Gear Shop.
Beacause there will not be enough space to bolt up the licence plate without interfering with the blinker bolt and washer, I decided to go to Pep Boys to see what could I find. Found some lower license plate bolts that were designed to stop license plate rattle. Part #81400. Back side is flate so works perfectly.
Cameras & optics Camera accessory Lens Camera lens Photography
Lastly I purchased license plate led screw bolt to light up the license plate. ebay $10.00
2X White LED Motorcycle Car License Plate Screw Bolt Light Black US Seller | eBay
And here it is all fished. Much better looking than stock in my opinion.
Vehicle registration plate Automotive exterior Signage Auto part
Hope you liked it, let me know you thoughts. Thanks for looking.
1 - 1 of 1 Posts
