1 - 8 of 8 Posts
I have a 2013 4runner which I replaced the oem horn with bosch europa.
Now one of the piece from 4runner oem horn found its place on my Grom and luckily it centered.
Motor vehicle Vehicle Auto part Car Wheel
backside of the horn:
Auto part Automotive lighting Vehicle Car Engine
not much to it, just take out the oem horn assembly and install the car horn with its built in brace.
Note: grind a portion of top brace to fit in the frame notch and since front frame is not grounded use the oem ground wire (the shorter one of the two) positive wire should be the longer one with bluish color.
Make a short extension wire complete with connectors from new horn just incase you need to install back the oem horn this will maintain the oem electrical harness.
The brace:
Tire Automotive tire Wheel Automotive lighting Auto part
Since the oem screw is too long I have added three lock washer :)
Now the look:
Land vehicle Vehicle Motorcycle Motor vehicle Automotive lighting
How much louder is it over stock may I ask....significant ?
Discussion Starter · #3 · (Edited)
It's loud. I tried posting the video but didn't work. 2.5 times the oem sound plus it doesn't sound like a motorcycle :) if someone wants to post the video I can email it.
I tried emailing it to you but it keeps telling me I exceeded the file size limit. I am not a techie guy but the video info is:
kind: MPEG-4 movie
size: 76,604,387 bytes (76.6 MB on disk)
dimensions: 1080 × 1920
duration: 00:36
codecs: H.264, AAC
Sorry!
1 - 8 of 8 Posts
