1 - 10 of 10 Posts
I’ll be finalizing my prep this evening for my official attempt at a Bun Burner 1500 ride (1500 miles in < 36 hours). All the fuel stations along the route were contact last night and confirmed to have 24/7 fuel access at the pump. Credit card company has been notified of travel. Chain is adjusted and oil is full. Pockets? About to be stuffed with meat.
The Idiot: Me
The Machine: The mighty 124.9cc Honda Grom. Fuel Capacity: 1.45 US gal / Avg Fuel Economy: ~85 MPG / Approximate Range: 123 mi per tank / Back-up Fuel: 50 oz (33 mi) / Top Speed: 52-64 MPH, depending on windage and grade.
The Route: 1509.7 miles covering 5 states – no interstate riding. Departing Saturday 9/7 @ 7AM from the Mobil station in North Lake, WI (Rt 83 and VV) heading north towards the UP. Final stop is the same station in North Lake, hopefully by 7PM on Sunday. An average of 15 minutes per gas stop was allotted (3.5 hrs total), leaving just shy of 3.5 hours of “buffer” to complete the ride (which will all likely get used).
Tracking: I’ll be using a combination of free apps (Maps.me, Spotwalla, and SWConnect) to document and track my ride. GPS positional updates will be uploaded every 5 minutes (buffered for later upload, if cell reception is not available).
If you care, you can check in during the ride for real-time positional info via these links:
Spotwalla Tracking
Spotwalla Tracking (ALL Data Points)
If everything goes to plan, I should be back to the office on Monday!
Good Luck and ride safe, be sure to carry a action video camera, wear reflective vest so the real idiots out there can see you.
Carry chain lube and tools to adjust the chain if you are using OEM chain or switch over to O-ring chain but still carry chain lube, quick fix tire patch, etc, small solar panel to charge your smartphone and other batteries, check and make sure your oil drain plug is safety wired and also your cam chain plug. Check and recheck the whole grom for possible nuts/bolts vibrating loose.
Ride it like you stole it. Be safe
I went to the Scottish games this pass weekend so for your ride I present a Scottish Safe ride send off. Borrowed video off the youtube
Got all the gear suggestions covered, thanks! Hopefully the Cobrra chain oiler I recently installed will minimize chain issues. I actually have ~2800mi on the Grom (OE chain) and just did my first chain adjustment last night. It was still technically in spec, but I tightened it up slightly to 30mm for good measure.
I also wired in a usb charging port to power my phone and charge my headsets.
I paint marked a bunch of fasteners after verifying torque to get a quick visual to make sure nothing is loosening, but I should do the cam chain tensioner just to be sure.
Appreciate the suggestions!
I also posted this over on the ADVrider forum:
Hey all! After recently completing my first SaddleSore 1000 and Bun Burner 1500 ride, I'm proud to say that I'm a "pending" member of the Iron Butt Association; documentation has been submitted for official review and approval! I was able to accomplish this feat on my 2015 Honda Grom!:wings
Other than a couple of minor bolt-ons and cheap mods, the bike is pretty much stock, and I purchased used [read: budget friendly] parts, where possible, to make it a little more comfortable for the ride.
I purchased this Grom new in spring 2015 and all of the 2843 miles on the odo prior to this trip were entirely commuter miles. These were more-or-less the first "fun ride" miles on the clock.
Since I had never done a Bun Burner, I also needed to successfully complete a nested Saddle Sore 1000 to qualify for the BB1500. I spent an extensive amount of time between Google Maps, Google MyMaps, and maps.me (iPhone app) to plan a route devoid (almost completely) of interstate riding. My mighty Grom has a top cruising speed of 45-60MPH (usually closer to 50-55 MPH) depending on windage and grade. I was on the interstate briefly around Duluth, MN to get around the southwest end of Lake Superior, but luckily the speed limits on this stretch were 50-55 MPH, and it was mid afternoon on a Saturday when I passed through, so traffic was fairly light.
Spotwalla Trip Tracker:
https://spotwalla.com/tripViewer.php?id=1f1855d6fe41984428&hoursPast=0&fillFactor=100
At any rate, I based my fuel stops off my average commuting fuel efficiency of 85 MPG since installing the cam (600 miles before the start of the IBA ride). I also carried along 50 oz of reserve fuel in MSR fuel bottles. Based on the tank capacity (1.45 gal) and my reserve fuel, I figured I could go ~120 mi on a tank + ~30 mi reserve before being in trouble. In trying to maximize efficiencies, I planned several fuel stops 110-125 miles apart. Imagine my surprise when my reserve light started blinking at 65 miles, and I ran out of gas at 84 miles! 11 miles short of my first fuel stop!! :hmmmmm
Truth be told, I'd never gone a full tank at 100% WFO, and my fuel economy was actually closer to 65 MPG (~94 mi per tank + ~25 mi reserve). I had to add an additional 7 fuel stops to the original 15 to ensure I had enough fuel.
Here's the digitized trip log:
A couple other fun facts about the ride:
  1. My plan was to eat on-the-go, but 6 hours into my ride, I realized there wasn’t enough clearance between my face and my helmet to get food into my mouth. I crammed a little food in a fuel stops, and but the "food" for my ride consisted of some sausage sticks, a couple Gu Energy packets, and a few pieces of beef jerky. I was so focused on riding that I forgot I was hungry.
  2. I did not have a single fuel stop that lasted longer than 17 minutes, including drive chain adjustments; most were substantially faster.
  3. Riding was straight-through. No sleep breaks. I set a new personal record of 37.25 continuous hours without sleep (including the morning before the ride and time at home to hang up all my wet gear before falling asleep).
  4. I got stuck in a downpour in IL before hitting Rockton and my pants leaked. Most miserable riding of my life ever was the last 3 hours of the ride (and only because of the wet arse). If that had happened earlier in the ride, I never would have made it.
Thinking I might attempt an IN-STATE BB1500 ride next spring/summer on the Grom (after upgrading the gear to something more water resistant). :loco
Cheers!
Mikey
P.S. I wanted to mention that Barb at Alaska Leather actually donated a size small sheepskin Buttpad to me for this ride. The pad worked great, and really helped damp out the vibrations caused by the firmer Corbin seat. It also kept my rump nice and toasty during the cool evening.
Uufda. That's one hell of a ride. How was Duluth on the mini bike? Did you have to ride up the big hill heading out of town?
edit: Oh and awesome plate!
Discussion Starter #10 (Edited)
Haha! Awesome!
Lots of hills on that ride. Out of Duluth and particularly all along Rt 2 along the UP. Some in IL coming out of the Mississippi River valley. Nothing that 3rd gear (sometimes 2nd) couldn’t handle.
ETA: I think I need to gear down a little with my KOSO cam. Still running stock gearing and it’s pretty flat at and below 6000 RPM. Not sure I want to go to -1 on the front, though. Need to run some numbers.
1 - 10 of 10 Posts
