1 - 20 of 30 Posts
I have been screwing with my grom a little and I have noticed all the bolts are torqued to over 2 times what's in the manual.
The front axle on my bike was torqued to over 100 ft-lb, this will make the front wheel bearings wear out prematurely. The front wheel torque is 40 ft-lb and the rear is 44, the front brake caliper is 22 and the fork pinch bolts on the triple trees are 20. I hope these torque values are a help to everyone. Also, the front and rear axles have NO grease on them. Pretty typical for a Honda
I could be wrong but I dont think a tq wrench works accurately in reverse. Also I dont think the axles need greese I think the bearings need grease. But like I said I could be wrong.
Well, the torque wrench does work in reverse when it's a snap-on needle style,(what I used ) and an axel does need grease unless you want to beat it out with a hammer in 5k miles( water will cause the clear zinc to corrode on the axel ). I use to work as a mechanic at a honda dealership so I do know what I am talking about. Honda usually uses very little to no grease, Yamaha on the other hand isn't as cheap with the grease.
The front axle on my bike was torqued to over 100 ft lb , this will make the front wheel bearings wear out prematurely . The front wheel torque is 40 ft lb and the rear is 44 , the front brake caliper is 22 and the fork pinch bolts on the triple trees are 20.
Either someone put your axles in with an impact gun or you're reading the amount of torque necessary to overcome the static coefficient of friction when pulling it apart.
Torque values are set via the dynamic coefficient. That's why stopping in the middle of torque procedure to reposition the wrench/ratchet can give a false value.
I had to use a 1/2" drive two foot long breaker bar to get my shock bolts out. And I had to muscle it.
I can believe what the OP is saying. I had an FZ1 new and EVERYTHING was loctited and torqued WAY over spec. It was a total bitch doing any work at all.
Its a liability thing. One bike has one bolt that comes off and somebody gets hurt and sues.
So guess what those nuts and bolts get the stuff torqued out of them from the factory.
Does anyone know what these should be torqued down to?? Just did some mods and just wanna make sure we're all good. This will help us all
  • HANDLEBARS (4)-??
  • HEADER BOLTS(2)-??
  • OIL DRAIN PLUG-
If any more should be added that aren't in this thread, feel free to add to it.
Thanks in advance
TORQUE VALUESSTANDARD TORQUE VALUES
ENGINE & FRAME TORQUE VALUES
  • Torque specifications listed below are for important fasteners.
  • Others should be tightened to standard torque values listed above.
    BODY PANELS/EXHAUST SYSTEM
FASTENER TYPE
TORQUEN·m (kgf·m, lbf·ft)
FASTENER TYPE
5 mm bolt and nut
6 mm bolt and nut(Include SH flange bolt)
8 mm bolt and nut10 mm bolt and nut12 mm bolt and nut
5.2 (0.5, 3.8)10 (1.0, 7)
22 (2.2, 16)34 (3.5, 25)54 (5.5, 40)
5 mm screw
6 mm screw
6 mm flange bolt
(Include NSHF) and nut
8 mm flange bolt and nut10 mm flange bolt and nut
4.2 (0.4, 3.1)9.0 (0.9, 6.6)12 (1.2, 9)
27 (2.8, 20)39 (4.0, 29)
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Body cover and tailcover mounting screw
4
4
0.9 (0.1, 0.7)
Exhaust pipe cover bolt
14 (1.4, 10)
Exhaust pipe mounting nut
27 (2.8, 20)
Exhaust pipe mounting bolt
1
8
27 (2.8, 20)
Exhaust pipe stud bolt
See page 2-10
Front fender mounting bolt
6
6
12 (1.2, 9)
Front cowl mounting bolt
4
6
12 (1.2, 9)
Muffler band bolt
1
8
20 (2.0, 15)
Muffler mounting bolt
1
8
27 (2.8, 20)
Muffler mounting nut
1
8
27 (2.8, 20)
Muffler protector bolt
1
6
14 (1.4, 10)
Rear fender stay bolt
31 (3.2, 23)
Seat lock bracket bolt
14 (1.4, 10)
Shroud screw
4.2 (0.4, 3.1)
Shroud tapping screw
20
4
0.9 (0.1, 0.7)
Sidestand lock nut
1
10
30 (3.1, 22)
U-nut
Sidestand pivot bolt
1
10
10 (1.0, 7)
Sidestand switch bolt
1
6
10 (1.0, 7)
ALOC bolt; replacewith a new one.
MAINTENANCE
PGM-FI SYSTEM
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Air cleaner cover screw
8
5
1.1 (0.1,0.8)
Air cleaner element screw
1
5
1.1 (0.1,0.8)
Spark plug
1
10
16 (1.6, 12)
Crankshaft hole cap
1
30
8.0 (0.8, 5.9)
Oil drain bolt
1
12
24 (2.4, 18)
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Bank angle sensor mounting nut
10 (1.0, 7)
Fuel injector joint mounting bolt
12 (1.2, 9)
EOT sensor
1
10
14.5 (1.5, 11)
Apply engine oil to thethreads and seatingsurface.
O2 sensor
1
12
24.5 (2.5, 18)
GENERAL INFORMATION
LUBRICATION SYSTEM
FUEL SYSTEM
ENGINE REMOVAL/INSTALLATION
CYLINDER HEAD/VALVES
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Oil centrifugal filter cover bolt
12 (1.2, 9)
Apply locking agent tothe threads.
Oil pump assembly bolt
5.2 (0.5, 3.8)
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Fuel filter stay nut
12 (1.2, 9)
For tighteningsequence See page7-5
Fuel pump setting plate nut
12 (1.2, 9)
Fuel pump setting plate special nut
12 (1.2, 9)
Throttle cable stay screw
1
5
3.4 (0.3, 2.5)
Connecting hose band screw
1
4
1.5 (0.2, 1.1)
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Engine hanger nut
(upper)
1
10
54 (5.5, 40)
(lower)
1
10
54 (5.5, 40)
(front)
1
10
54 (5.5, 40)
Drive sprocket fixing plate bolt
12 (1.2, 9)
Step holder mounting bolt
31 (3.2, 23)
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Cylinder head cap bolt
4
8
24 (2.4, 18)
Cam sprocket bolt
1
8
27 (2.8, 20)
Tappet adjust nut
9.0 (0.9, 6.6)
Cam chain tensioner sealing bolt
1
14
22 (2.2, 16)
Cam chain tensioner arm pivot bolt
1
8
16 (1.6, 12)
Cam chain guide lower roller pivot bolt
1
6
10 (1.0, 7)
Timing hole cap
1
14
6.0 (0.6, 4.4)
Crankshaft hole cap
1
30
8.0 (0.8, 5.9)
CYLINDER/PISTON
CLUTCH/GEARSHIFT LINKAGE
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Cam chain guide roller pin bolt
1
8
10 (1.0, 7)
Cylinder stud bolt
4
8
See page 10-7
ITEM
Q'TY
THREADDIA. (mm)
REMARKS
Clutch center lock nut
1
14
64 (6.5, 47)
Clutch lifter plate bolt
12 (1.2, 9)
Gearshift cam plate socket bolt
1
6
10 (1.0, 7)
Gearshift return spring pin
1
8
30 (3.1, 22)
Oil filter rotor lock nut
1
14
64 (6.5, 47)
Right crankcase cover protector bolt
12 (1.2, 9)
Shift drum stopper arm bolt
1
6
12 (1.2, 9)
well , the torque wrench does work in reverse when its a snap on needle style ,(what I used ) I use to work as a mechanic at a honda dealership so I do know what I am talking about .
If we're playing the "appeal to authority" game, I have a degree in automotive engineering and another in physics, and I think you're wrong.
You can't even get close to telling what the bolt was torqued to by putting a wrench on and going backwards because there is static friction and often a small amount of corrosion between the shoulder of the nut and the surface it is pressed against. An assembly line typically uses those really expensive drivers that torque things exactly where they need to be and require basically no skill to use correctly, which is good because the people assembling things don't have any skill as you can see by looking at the welds.
That said, yes the axles should be removed and greased lightly anyways.
awesome,thanks for that info. is this for our groms??
1 - 20 of 30 Posts
