1 - 6 of 6 Posts
BMC High Flow Air Filters are better than OEM filters, Synthetic Filters & other Cotton Filters.
BMC Air Filters are of the highest quality & put under the most severe testing to create a Superior Air Filter.
Just click on the link below for more information & pricing.
>> BMC High Flow Air Filters <<
How much better performance is achieved with chimera ( sp?) vs this?
Unfortunately, we have not had anyone do a Dyno run back to back to back
Stock vs. BMC vs. Chimera
honestly it really comes down to 1 question
Do you want to retain your Stock Air Box.
If you do.............. then the BMC is the way to go.
If you want to shed some weight (removing Air Box), ... ADD some GROWL, and ADD little more Pep......... Then Chimera is the way to go.
The Fact the Chimera is sort of "Ram Air effect" we believe is the reason soo many have found it to give the bike a good kick in the pants.
Either way you go............ at least you have a washable Filter, that lasts pretty much forever.
I added one and it was great i was clearly faster than my buddies bike vs his stock filter modded. The surface area alone is almost double.
So other then the BMC, your bikes are the same ?
1 - 6 of 6 Posts
