Update: 3 Grom Builds. Blaze Yellow/blk, Pink/blk, KOSO BBK
Updated 5/9/17
Alright, 3 Builds. One Thread.
My Bike - Blaze Yellow/Black Grom (Stunt)
A bike I can commute, stunt, road race, mx., little bit of everything kind of bike. (now solely a stunt bike 5/9/17) I'll be updating my input in for the majority of what I install and test so feel free to ask questions.
Current odometer (2/23/2017 - 11,600mi) error on last update
Mods-
KOSO 170cc 2v (Jones Honda) (currently back to stock piston/bore)
KOSO 34mm Throttle Body (Jones Honda)
KOSO 34-30.5mm Intake Manifold (Jones Honda)
KOSO bigger connecting tube/intake tube (Jones Honda)
KOSO Camshaft (Jones Honda)
Finbro Big valve Head with intake side port matched to koso intake manifold (finbro garage)
Finbro ECU (Perfect Stranger Designs)
PCX injector
Forza 300 fuel line
KOSO AFR Gauge (Jones Honda)
Kitaco Cover (Hard Racing)
Takegawa Super Oil Pump (Hard Racing)
Intake Mod (Jones Honda)
KOSO Hurricane Filter (Jones Honda)
Power Pures Front and Rear (120 & 130) (recently swapped to a dunlop tt93 front with vee-rubber rear for stunt riding) (Jones Honda)
Magura HC1 Handbrake (Jones Honda)
Brembo P34 caliper (Perfect Stranger Designs)
PSD Subcage (Perfect Stranger Designs)
PSD dual caliper bracket (Perfect Stranger Designs)
Exhaust - Black DG Low Mount (Have had quite a bit of experience with Yoshimura, Akrapovic, DG, FMF, and DKS) (Jones Honda)
Goodrich Stainless Front Brake lines (Jones Honda)
Goodrich Stainless Rear Brake Lines (have but not installed) (Jones Honda)
EBC HH front and rear Pads (Jones Honda)
EBC Contour Rotor (Jones Honda)
Pro taper Pillow Tops (Jones Honda)
Pro taper KX High bend fat bars (Jones Honda)
Pro taper universal risers (Jones Honda)
Slim style Left Hand Control Switch (Jones Honda)
EBC Clutch springs (Jones Honda) Need to get some that are stiffer though.
Euro Spec Headlight (Steady Garage)
LED Flasher Relay (Steady Garage)
Oil Decompression cap (Steady Garage)
Dual Catch Can, fittings, and oil hose - (harbor freight + O'reillys)
Fulmer LED light kit (Jones Honda)
Plastics and wheels dipped as well, soon to be powder coated.
2017 Honda Grom (race) 12.20hp
Emgo Drag Bars (Jones Honda)
ROX risers (Jones Honda)
Motion Pro Rev2 Throttle (Jones Honda)
Flushmount front signals (Jones Honda)
Dunlop tt93 tires (Jones Honda)
2015 wheels (weighed the front alone at 2lbs heavier, didn't get a chance to weigh the rear, I have heard it's 1lb per wheel difference?)
RK Chain (Jones Honda)
Superlite Sprocket (Jones Honda)
PSD Chain adjusters (Jones Honda)
Galfer Lightweight front and rear rotor (Jones Honda)
Galfer pads (Jones Honda)
Galfer front and rear stainless lines (Jones Honda)
Yoshimura RS2 exhaust (now FMF) (Jones Honda)
Dinger Built Intake
Evap delete, tail fender delete, signal delete
Pro Grip "soft touch superbike" grips (Jones Honda)
Pink & Black Grom (17.5hp)
-KOSO Camshaft
-DG R-Series Low Mount Exhaust
-Intake mod with lid removed
-Finbro Big Valve Head port matched to koso tb
-KOSO 170 big bore
-KOSO 34mm Throttle Body
-KOSO 34-30.5mm intake manifold
-Finbro ECU + PSD Cold Fix + PCX injector
-16t JT Front Sprocket
-Tyga Tail Kit
-Hot Bodies Front Turn Signals
-Competition werkes taillight
-Pro Taper KX high Handlebars
-Pro taper universal risers
-Pro Taper Neon Pink Grips
-Pink Vinyl Wrap
-Stainless front line
-EBC Contour rotor
-EBC HH front pads
The Shop Grom (parted out and sold) 23.5hp
- Mini 3 Handlebar bracket - 0 miles
- Mini 3 AFR Gauge - 0 miles
- Tyga X-Tail Kit - 0 miles
- DG Silver Low Mount v1 Exhaust
- KOSO Camshaft
- EBC Clutch Springs
- KOSO Camshaft
- KOSO 170cc Big Bore Kit
- KOSO 4v Head
- KOSO 34mm Throttle Body
- KOSO Intake Manifold
- KOSO Hurricane Filter
- KOSO Connecting Tube
- KOSO Rubber Intake
- PCX150 Injector
- Aracer Standalone RC1 Super
- Aracer AF1 module
Our shop grom has since been put back to stock.
Some before and after shots of mine. More updates to come
Updated 5/9/17
Mods-
PCX injector
Forza 300 fuel line
Dinger Built Intake
-KOSO Camshaft
-KOSO 170 big bore
-Tyga Tail Kit
-Pink Vinyl Wrap
-EBC Contour rotor
-EBC HH front pads
- KOSO Camshaft
- KOSO Camshaft
- KOSO 4v Head
- PCX150 Injector
- Aracer AF1 module
