1 - 20 of 24 Posts
Blake's Grom Rebirth
Good luck with the rebuild! Sorry you took a spill but at least you are getting back on it.
I can't offer much help with realigning the front end. I'm sure someone will be able to help.
Blake. If nothing is bent, it's simple. loosen the axle nut
Loosen the lower fork pinch bolts
You may hear it snap back into place
Bounce it up and down a few times
Tighten up the bolts starting from the top bounce, then torque axle nut.
If that die sent do it you need to see if something is bent. The axle is tiny.
Thought it would be something along those lines, thanks for the advice. Do you happen to know the torque on those allen bolts/axle bolts?
Also " if that die sent do it you need to see if something is bent" - can you reword that?
Maybe consider adding some leathers or similar to your shopping list? They're a lot cheaper than even one hospital visit. : )
Jacket and new helmet is all ordered too, will think about some gloves too!
Thanks for the support guys, waiting on these parts are killing me
Discussion Starter · #14 ·
Got more parts in today! But some of the hardware for the plastics are still on back order so looks like im going to have to wait to have her all dressed up, So everything but the plastics are going back on tomorrow!
But here is a project i'm working on in the mean time
Ignore the tape, was using it to mock-up
Tron bike anyone?
Blue Neon Light Lighting Neon sign
Discussion Starter · #15 ·
So its been a while since I updated my build thread so here goes
Vehicle Motor vehicle Auto part Engine Car
Had to completely tear down the front end to put on new top and bottom bridge
Technology Electronic device
Land vehicle Vehicle Motorcycle Automotive tire Tire
Front end back on and all aligned, oem bars back on too
Land vehicle Vehicle Motorcycle Automotive tire Motor vehicle
Everything back on except for body plastics, did a quick test ride all was good!
Auto part Engine Vehicle Automotive engine part Fuel line
Composimo cocking flange and k&n filter on.
Automotive tire Disc brake Vehicle Tire Auto part
adjustable Shorties and bar end mirrors with renthal barz
More to come
Blackberry 10
Discussion Starter · #16 · (Edited)
Tyga carbon side cowl, front fender, tank cover, MNNTHBX shroud brace
Land vehicle Vehicle Automotive tire Tire Automotive lighting
Vehicle Motorcycle Supermoto Automotive tire Rim
H2c crash bungs for front and back and red rim tape, still need to do the rear wheel but I'll do that when I get my power pures
M4 exhaust, composimo tidy tail with Thai spec indicators
How she sits now. Let me know what you guys think
Land vehicle Vehicle Motorcycle Car Motor vehicle
Land vehicle Vehicle Motorcycle Car Automotive tire
Blackberry 10
Looks great. Keep an eye on that M4 as several folks have found cracks.
1 - 20 of 24 Posts
