Hi people, its me again
Now I'm thinking to make my smile biggest with my Monkey, and sounds as the best way is a BBK. I can find a lot info for Groms, but Monkey is similar but not the same (in example the grom maps don't work in the monkey, very bad as exist lots of maps available for Groms). Now my primary decision are between a Koso 170 4V or the Kitaco Neo 181 (any other option is very welcome).
I'm a 51 years old street hooligan but not a track person in all of my bikes, so the idea is have fun on the street. I don't like be to much radical, maybe a 15-17 Hp goal is perfect, and a big smile on the streets. I like that any solution be as most close to OEM as possible (that looks like factory), aka so no one without a expert eye can say that something is changed (thanks God most kits can be obtain in raw silver and not only in black, but if is black I can remove the paint :wink
, so a oil cooler or ram air is discarded. The additional goal after install (the reliability is the first one), is that everything original is working the same way as come from factory (speedometer, starter, smooth run, etc)
The change needs to be very reliable. the temperature needs to be controlled, I don't like to need check oil or delicate parts every day after come home, or be scared about temperature every time I use the bike, or after 3000 miles needs to redo the engine (I don't have the time or the spare money for that), I like to have plenty of power in the mid range as I use the bikes most in downhills/uphills roads and only a 20% in a highway or flat areas, so nothing extreme, but a big smile, remember the big smile...
I have in my hands a Yoshi RS-3 full exhaust, the Takegawa filter element, and a DJ Power Vision 3 (maybe I need to add a WBX Single Channel to the PV for a small time to finish the correct map and a temp gauge, but the idea is remove after the maps are done).
So people, any help is very welcome, 2 points to take care are: 1. I don't like to break the bank and 2. I don't have access to a Dyno here in my country.
Any help and opinions or experience is very very welcome, the idea is to purchase all that is needed at same time to accomplish my goals (remember the big :big smile
An additional questions: a Oil Catch Tank is needed? I read in some places that is, other no, that is good to down the temperature, etc
Thanks in advance,
Dariusz
Thanks in advance,
Dariusz
