These are simply fantastic units. They're up on MNNTHBX - Enter now, and are available with an optional MNNTHBX exhaust / DCR cam / intake specific map, or the Bazzaz base map.
Z-AFM self mappers and stainless bungs are up on the site as well.
Benefits
'Wakes up' performance
Crisp and responsive throttle
Smooths out throttle transitions
HP and torque gains
How it Works
Power is dependent on how well the air / fuel mixture is ignited in the cylinder.
Air / fuel ratio (AFR) is controlled by the engine control unit (ECU).
Bazzaz fuel controllers piggy back onto the Engine Control Unit (ECU), intercepting the signal sent to the fuel injectors and changing it.
The precise data for these changes is stored in the Z-Fi fuel controller in the form of a fuel map.
The Z-Fi comes pre-programmed with an enhanced fuel map for power gains and improved throttle response.
Benefits
HP and torque gains
How it Works
