1 - 12 of 12 Posts
so i was in search of bar end mirrors, and looked like it should be easy enough. then i read you have to get a slide hammer or drill out the bars and so forth.
did some research and found out, and the reason i started this thread
Driven mirror bar end pieces screw right into the OE bar plug thingy.
so i just wanted to start an end all thread for when the next person searches bar end mirrors
about $18-20/ea
but IMO well worth the result and ease.
left easy peasy
right could take a few washers to shim it out, but that was the side i was beating on.
and lastly the part #
you'll need 2 if you're doing both sides
not sure if CRGs will work, i don't think they will
haven;t ordered yet as i didn't know if this was going to work or not, should be here wed.
CRG arrows, had them on my last bike too.
found these pics, those are bolt on bars, i'm using OEM bars
they're pricey
Reactions: tripage
Got mirrors in, easy install
BUT left side lever hits base of mirror
Looks like short levers next
Before you do that, why not rotate the arm holding the mirrors 180 deg's or drop your levers to clear the arm end?
Problem should be able to be adjusted from what your problem is.
Adj clutch lever out, got It too clear
Already ordered some chazzos, $30, all black
See how much wider then reg bolt Vehicle Automotive tire Tire Supermoto Suspension
on mirrors
1 - 12 of 12 Posts
