While removing my air box and install my new MNTHBX air box delete rod i wanted to do something with the horn that hung down in the front. Here is what i did...
1. removed horn and the bracket fro the lower tree.
2. re-routed wire after i unclipped the cable tie that hold the horn harness to front frame and routed it up and down along the main harness to the left side top old air box 6mm bolt mount. Using the exciting hardware mounted it up to that top hole in from under tank where the air box bolt was on left side.
this clears the left faring nicely and also clears MNTHBX delete rod as well. Horn is still loud and is completely hidden.
FREE HORN MOD RELOCATOR!!
