1 - 11 of 11 Posts
Those 2 pics you are referring to:
There is still part of the bearing (outer) in that hub. Use a long drift punch & hammer from the opposite side and bang it out. Work your way around the bearing with the punch. Do not always punch in one place.
If you get a new bearing you will see what I believe is the outer portion of the bearing still stuck in there.
If you have access to a press you can use that too.
Reactions: n8der
yes, still there.
take it a machine shop or a business that knows what is going on like a speed shop that does service. you could ruin the wheel.
In severe cases I have had to grind a chunk of the outer bearing out so it would come out.
Thanks. Yea is pretty bad. I think it failed because of a poor designed dual caliper bracket. Foot brake caliper sits on top of rotor. HB caliper sits on the bottom of rotor. With an oversized rotor. I don't know for sure if that's why it failed but I definitely abused the rear brakes. I'm gonna try a new dual caliper bracket as soon as I get this sorted out. Thank you WV Grom for you're help.
No problemo.
FYI: Normally I would suggest a bearing kit from All Balls, Pivot Works or Moose. In this case, with your using a dual caliper I suggest OEM Honda bearings.
Look at this fische and familiarize yourself with the innards of the hub. Might not be a bad idea to take the wheel to your dealer. Replace all 3 bearings & seals. #8 the collar may be roached too.
https://www.morgantownpowersports.c...R_WHEEL/GROM125-18-THA-AC/14K26H01AK26AF1940A
Let us know how this shakes out.
I got it out with a dremel and didn't mess up the hub anymore then it already was from failing. It wasn't the prettiest thing inside the hub but it will do for now. I didn't bother ordering a spacer because I have a new wheel on the way. I also picked up a new dual caliper bracket. The Chimera big rotor bracket which I highly recommend and its one of the cheaper brackets out there. Solid bracket.
before it blew up did you hear any random knocking noises coming from the rear wheel or anything that would warn you it was wearing down? I have this weird sound coming from the rear every once in awhile... its not every stop but if I ride for a hour ill hear it a few times here and there when I'm coming to a stop usually with clutch in because that's when bike is the quietest but it doesn't sound like its coming from the engine and I have no clue what it is. but I'm thinking mine is going to do the same if I don't replace it soon. though its not really getting worse..
Discussion Starter · #10 ·
Yes I hear a lot of noise on coaster's but if you're worried. Take off you're helmet and pull the clutch in and listen. I have caught a bad crush drive bearing on a 636 with my helmet off but it's kinda of crazy a bike with such low HP toasted a bearing with no warning like this.
Mine failed from a bad dual caliper design. It was a horrible design and that company is out of business now.
Also from what I have read here from other member's posts.. sometimes the spacer's are not in spec....especially early model Grom's (2014). The spacer's might be a millimeter off on the sprocket side or brake side. If you have an early model Grom i would definitely check.
I've read on here rear bearings failing at 300miles. Early model Grom's the spacing was not correct.
I'm just glad I got that bearing out. It was not fun.
Good afternoon! Wondering how common rear wheel bearing issues are with these things?
have a new 2022 w/ 4k on the dash and it appears my rear bearing just took a dump. Lateral wobble on the wheel abt 1/2-3/4”, popping every second or 2, not necessarily in time w/ speed but close. More noticeable after I tap rear brake. Feels like I have a flat rear tire and brake dragging. Caliper is clear and chain is good. Wheel is aligned.
thoughts? Thanks in advance for any advice.
1 - 11 of 11 Posts
