1 - 10 of 10 Posts
Assembling of Finbro 125cc Stand-alone ECM with BoosterPlug
Hi guys,
My 2015 Honda MSX has a front 14t sprocket, an air filter mode, a full system Akrapovic slip on carbon and a BoosterPlug: http://www.boosterplug.com/shop/boosterplug-honda-msx125-439p.html
I would like to add Finbro 125cc Stand-alone ECM: http://store.hardracing.com/cart.php?target=product&product_id=31463&category_id=2690
My questions: Can they work and operate together? Will the ECM provide a big improvement in performance compared to the BoosterPlug?
Many thanks!
Hmm. This is a new device to me. For anyone that is wondering, it basically just fakes a lower temperature to the ECU, which gives it more fuel. But.. the ecu would trim that back using the O2 sensor... hmmm. Detailed explanation on the BoosterPlug First place ive seen that describes how their magic box works in such detail. It also gives you a basic understanding of how the ECU operates.
And... From what ive heard on the finbro ECU, it does not use the air temp in its maps, so coupled together, this would be useless.
Rather than this, might i suggest an EFIE type device that fakes the O2 sensor's voltage to something lower, so the ECU adds more fuel. I think those run more in the 30-50$ range. -- whoops. didnt read you already had the boosterplug.
Discussion Starter · #4 ·
Thanks guys, the Finbro 125cc Stand-alone ECM is not an ECU, it is ECM and behaves differently. There are no tunings!
I am going to fix the Finbro ECM + pcx injector for the stock 125 motor by the end of the week, I will keep the BoosterPlug and update you how will my baby behave!
Finbro ECM does not read the air inlet temp sensor, therefore the booster plug will do no good. Also no cold start solenoid or kickstand safety switch functionality.
Thank you again guys, for your explanations! I will update in few days. I am married 31 years and I simply fell in love again!!
And this is my bike.... Land vehicle Vehicle Motorcycle Supermoto Car
Dear friends, today I installed the Finbro 125cc Stand-alone ECM + a larger injector. We had to remove the BoosterPlug, also according to your advice.
The bike is stronger and have more power. The most important thing for me is the acceleration between 0 to 70-80 km per hour, just what I needed.
1 - 10 of 10 Posts
