1 - 5 of 5 Posts
Are 1st and 2nd get ecus the same? Anyone know for sure? 1
They are wired slightly different, but are backwards compatible with some repinning.
mind telling me what pins on the 14 I needs to move to make the 18 ecu work? and can I use the 14 ecu on the 18? I trying to sell my 18 so I'm trying to put all my good parts form 18 on my 14
Thanks for that, I actually ended up comparing the to wiring harnesses and just switch both, turned my 18 into a 15 harness, and my 15 into an 18 harness. But yea 4 pins need to be switched around on both sides. Both bikes run fine now.
I'm sure someone else is going to need this in the future for sure. Not sure if there be more stuff to do if the 18 was ABS, mine isn't
1 - 5 of 5 Posts
