Several hundred miles now since the upgrades & app update. Bike is running amazing! I have added timing back where I had pulled it to combat the idle hang. Pard, I have discovered that with closed loop turned on, and Dec Fuel Cut (DFC) on, there is ZERO idle hang, but every time I turn those off & try to auto-tune again it is there. After AT session, turn CL & DFC back on, idle hang is gone.
Cliff notes: Yuminashi 143 kit + MiniX + AF2 + Wicked Grom AF2 power harness + heavily ported head matched to Koso 30.5 to 34mm intake + 34mm Throttle Body & 120cc injector + just added a 2" diameter 90 degree silicone hose & aluminum coupler so I could get the filter off the TB (did weird midrange things like that) = bike runs amazing! 70 mph GPS in 3rd gear, on a 14t front sprocket, amazing.
Going to the track Saturday for the 1st time with the 143 installed, should be interesting. Also going to head to the DYNO soon to get a proper tune, now that I FINALLY have all the bugs worked out.
