Bought these for my 2017 (still waiting for the AF2), figured I would start a thread to document my experiences, as aRacer is new to me.
Back story on my Grom as it sits:
Because the Yumi ECU was for OG I had to repin the harness (will reverse before installing aRacer stuff), and cold start DID NOT WORK, actually had to unplug the CS connector cause it made a hideous constant clicking sound with this ECU. Even the cold start settings for the ECU app/PC program DO NOTHING, so I have to hold the throttle until it gets some temp into it or it will stall.
Bike runs really good once warmed up, tops out around 82 mph GPS with a 14t front & stock rear sprocket (full tuck) & is super fun to ride. But the amount of time I spend getting it tuned could have been better spent enjoying the ride, & its still needs more dialing in to be "right".
For reference, my girl's OG has the same 143 kit, TB cam, stock airbox with a Koso tube & BMC race filter, that was tuned & flashed on DHM's dyno. Hers is 14.2hp & a tick under 10ft lb torque, & never needs to be adjusted, just works every time. She always gets a jump on me off the line til about 40mph, then I roll right on by & leave her....
Will update this thread once I get the AF2 & MiniX installed. If anyone has any pointers to get me going in the right direction with the aRacer stuff, feel free to chime in. I have been studying for a while before pulling the trigger & kind of get the gist of it, but expect a bit of a learning curve.
Don't know if anyone remembers this cam or not, but here's what they had to say about it:
- Yuminashi 143 kit (cheap AF, don't judge me..... LOL), may go bigger in the future (164 kit is pretty cheap too
- Old very rare in the USA, Yuminashi Hi Lift cam, originally came with their "160cc Ultimate" kit but was later sold separately (see specs below)
- Matching special Yuminashi Hi Lift (stock size) valves, double valve springs, and retainers (zero float even above 12.5k (limiter is set to 12.5 now & I try to stay off it))
- GromFatherz Rev Wedge, matched to a backcut OEM throttle body & ported head
- ported head, matched to a Finbro High Mount Exhaust (also rare in the USA)
- 120cc Yuminashi injector (have a 140 on standby, but do not see the need)
- Original DB Short Ram intake with K&N filter
- Yuminashi v9.1 Stand Alone ECU with BT app for tuning (old & hasn't been updated since 2019)
- WB O2 standalone gauge that also inputs to the Yuminashi ECU (BIG reason of all of this, no Autotune capabilities)
