1 - 11 of 11 Posts
It mostly happens when i gently touch the front brakes like in traffic...or just rolling the bike forward or backward, and turning the handle full to the left or right, without the engine on . I thought it would go away but it's still there and gives a noisy squeal. Is that temporary...like the pads need braking in...or do they need alignment?
Nope just a bit of rear brake squeal. It doesn't happen all the time. I mentioned it at the 600 mile service and the didn't find anything wrong and it didn't squeal for them. Will mention it again at the 2500 one
Mine do. But only with the lightest touch and only if cold. As soon as the pads have any heat at all they won't squel. Its normal.
Mine did for awhile (like... 600 miles) and it was only the rear. Now it does it very rarely and I'm at 900 miles
My rear still squeals at 1600 miles and my front rotor is most likely warped, I get a "tsst" in one spot if I roll it around
I've also been hearing a metallic "tsst" only when on the throttle, off throttle, clutch in, nada but as soon as I give it throttle it starts immediately, figured this was the front brake as well
1 - 11 of 11 Posts
