1 - 13 of 13 Posts
I finally got a k&n. Upon test fitting I realized the inner diameter is bigger than the throttle body. 43mm instead of the assumed 38mm. You guys sure these things are sealing up properly? Seems like they just get shoved in there with no verification.
Discussion Starter · #2 ·
Well here's my fix.
Material property Font Photography Hand Measuring instrument
At 43mm I didn't want to risk an improper seal
Audio equipment Footwear Floor Technology Shoe
Carefully cut off stock boot. (Nipped off little nub too)
Tire Rim Automotive tire Synthetic rubber Auto part
Insert into R-1100 and align tabs to fit
Camera lens Lens Hand Photography Camera accessory
Here it is flush
Measuring instrument Ruler Photography Tool Number
Oem 38mm achieved. Reinstall
Nice fix but I don't understand why you had to do this and no one else did. Now I am hesitant to buy one.
It's well known that they dont fit 100%. But apparently if you crank down on the hose clamp they still seal... I'm planning on getting a unifilter tho so better to check with someone who has done the k&n and run it for a while
Sent from my GT-I9505 using Tapatalk
Here's what I did...pulled guts from airbox, except for last piece of tubing that leads out of the box. Found that a 1 " PVC coupler fit PERFECTLY over the outer diameter of the rubber tube and fit PERFECTLY inside the inner diameter of the R1100. I Pressed the couple over the rubber piece, clamped the r1100 on the other side and voila!
Auto part
Auto part Vehicle Automotive exterior Car Automotive design
Auto part Vehicle Automotive design Engine Car
I can give you more detail if you want. Also did an airbox mod where I added a few washers to open a gap in the cover to let more air in. Though it was better than drilling holes in the cover. Auto part Fuel line Engine Vehicle Carburetor
Discussion Starter · #6 · (Edited)
I wanted to ditch the airbox all together. Went an alternative route mounting mine too.
Test fit everything. Saw and marked where the sensor would be. How the old air boot piece tabs would need to be placed. Which wire bracket had to go and how wiring had to be routed.
Auto part Engine Vehicle Fuel line Automotive engine part
Drilled sensor hole to about 5/16" (8mm)
Black Light Photography Floor
Left o-ring in place and inserted (allowing for connection wire to be relaxed and not twisted)
Auto part Automotive wheel system Cylinder Wheel Gas
Applied rtv sealant instead of adding screws and more holes.
Vehicle Auto part Motor vehicle Motorcycle Engine
A lil paint on the bracket I nipped off
Some oil on the filter and popped in place
Automotive exterior Vehicle door Bumper Red Auto part
Had to make a small relief to the shroud. Just used a dremel.
Auto part Vehicle Car Automotive exhaust Exhaust system
This is how it'll look. Pretty sexy huh? lol Still waiting on a few things in the mail. The crankcase breather hose will have a uni push in type filter and be a lil shorter and mnnthbx has a shroud brace headin my way. I'll finish it all up this week. Will probably also get an outer cover to keep under the seat for when weather requires such. Anyways, there's a different twist to the popular mod.
nice, hows the noise, i tried the washer trick and the intake noise was crazy the box acted like a amplifier. lol.
The washers thing worked well but I think you may be onto something with the box acting as an amplifier. I may try pulling the front cover of and do a sound comparison. It definitely seemed to help the mid range power.
Sent from my XT1060 using HondaGrom.net mobile app
1 - 13 of 13 Posts
