I've been lurking around for a couple months now and after reading just about everything I could find about porting the stock grom head I've seen no mention about recutting the valve/seat and blending the seat/throat/bowl.
I haven't been inside a grom head yet but I've been in over 60 holes (dont judge) and had a couple of 8v vw heads that were done professionally, and every single one of them needed work between the back of the valve and the stem guide. For the most part the valve seats are just pressed in at the factory, pressure tested and sent out the door, which usually leaves an appreciable ridge where the valve seat meets the head. Has honda addressed this issue for the grom? Ive "ported" 2 crf70 heads and they both needed the seats blended into the throat and tidied up behind the stem guide.
Also, why no mention of 3 or 5 angle grinds or radius cutting the exhaust valves?
