1 - 9 of 9 Posts
Hi Guys,
I've Just ordered myself a Takegawa clutch cover, Takegawa Oil pump (from straight up pumps), and a Big oil cooler (didn't come with oil lines or fittings)
I'm planning on making my own lines but I don't know what size is appropriate?
Also If anyone knows what size banjo bolts come with the takegawa clutch cover that'd be a bonus too?
Thanks in Advance
-4AN; 10 mm bolts. Can't remember the thread pitch.
-3AN hardware selection sucks, and -6AN lines are too big.
Thanks man, yeah I don't need to know thread pitch now anyways.
I'll go ahead and start to find the fittings I know the An4 - 10mm banjo hose end fitting is like impossible to find as well definitely an online order.
I thought it would be an4! 👍
As far as I know it doesn't come with any banjo bolts, only plugs. Banjo bolts should be M10x1.25.
And double check the cooler, some Takegawa coolers are M12.
Given the location, I would recommend non-conductive sleeves. Conductive stainless will chew stuff up quickly if not secured tight.
1 - 9 of 9 Posts
