1 - 3 of 3 Posts
This Softseat has an innovative design that allows you to customize the amount of cushion wanted. On the seat is an air release valve that allows you to choose how much cushion you want. Opening the valve will allow the seat to fill with air. Simply sit on the cushion and open the valve until the point of the desired cushion. The top of the seat has a suede finish whereas the bottom has an anti-slip material. This seat has two straps to attach to the original seat for a universal and secure fit. It also comes with a carrying bag for easy storage when compressed.
Check out the small softseat here!
Link is bad.
Link is bad.
Hopefully, this link works. It is all the products for the Grom and the softseat should be in there. Going through website maintenance and that probably hurt the old link, our apologies!
1 - 3 of 3 Posts
