1 - 20 of 71 Posts
Lots of aftermarket exhausts for the Grom but I have not seen any aftermarket air filters for it. I'm pretty sure K&N will make a drop in replacement. But was just wondering if the Grom would benefit from an open element type filter.
I heard through the grapevine that air box mods do help it. fwiw
Reactions: SouthernGrom
Definitely air intake and exhaust are first on my to-do list.
:wink:Has any one else been in contact with any of the big air filter companies to see if making anything? K n N said they had no plans as of yet to make anything as of yet .
my be if they more inquire it mite speed them on up development !
Good idea.
Im a little curious about the temp sensor in the stock air box and what I might do with it if I put an open element on.
I'm going to look into what it would cost to replace just the airbox cover. Then I plan on drilling a hole or two in the cover to open it up. If that creates a problem, I should be able to get a new cover for just a few bucks and in the meantime use duct tape to cover the holes back up.
Premium Member
You have been reading my mind again. What are you, the NSA?
I've tried with holes in the Cover, also tried to remove the snorkel in the air filter box, Did not it worked for me
I've tried with a bolt on Kn Filter directly on the Trottle body and the bike was leaning out " too much air "
jeg venter nu på min nye Preformance Fuel injector, then we will see whether the result is Better
How do you re-set the ecu?
How do you unhook the battery/ LOL JK. Thanks for the info.
1 - 20 of 71 Posts
