I am removing my air box so I can install a K&N Air Filter upgrade when it gets here. I also want to make some room up front above the intake valve so I can have a much easier time with the valve adjustments. A couple quick questions for those of you who have done this.
This hose runs from the back of the airbox on the left side of the bike over to the right side of the bike and into the top of the engine. What will I do with this hose when the new filter gets installed? Leave it somewhere? Remove it completely?
This bracket is held by the top of the throttle body and basically helped stabilize the air box with those rubber cushions that the air box rested in. Should I just screw this back into the throttle body or leave it off with the 2 holes open?
This is how the open throttle body looks now that the connecting hose from the airbox has been removed. Should I connect the new filter directly to this, or run a hose from here to the air filter, or run some type of pipe that I see some have already? What is the best way to set this up?
Any and all advice is much appreciated!
