Looking forward to it. Thanks man!In for later.
I'll post pics. on how to do the wiring and stuff.
Dude if you are going to tell us about your m9ds you need to post photos of those mods. Please.I put my front turn signals on today , I used honda flush mount blinkers for honda street bikes . blinkers are made by speed metal and I got them at cycle gear store , you could also use hot bodys or lp brand
Gromhawk......I followed these instructions but my LED turn signals wont flash and stays lit. I have an LL552 flasher installed too. Can someone help?Ok so here it is. I don't have any pictures during the install of the turn signals though. But I can guide you thru the wires. For the back you will have two green wires, those are the ground. the you will have a blue w/white stripe and a orange w/white stripe. Those are for the power. I can't remember which one goes for each side, so just plug and see.
Now for the front you will have three wires for each signal. One green, one blue, and one blue w/white. you want to cap off the blue w/stripe and just use the green for ground and solid blue for power. On the other side its green, orange and orange w/white. again cap-off the orange w/ white.
get the "electronic" one...not the electro-mechanical LL552Gromhawk......I followed these instructions but my LED turn signals wont flash and stays lit. I have an LL552 flasher installed too. Can someone help?
Thanks Cisco........this fixed the problem!!!get the "electronic" one...not the electro-mechanical LL552
Here is a link that might help you.
LED flasher Info LED Problems - LS1TECH
