1 - 20 of 24 Posts
In case anyone else is interested, I added a Givi A660 windshield to my Grom. It only has two attachment points.
The shield vibrates a bit at idle, but settles down, once I get my speed up. It does a good job of redirecting the air, up and over my head.
Nice! If the weather was worse here in the winter, I would do something like that. That looks much better than I thought. Good call. Proportions look good and it doesn't detract from the bike.
Looks good. Did you consider any small ( in height ) or sportier windshields ? Also did you lose much speed.
Thanks
Discussion Starter · #7 · (Edited)
I had the Givi on hand from my Rebel, so I figured I'd put it on there, just to see what it looked like. I was a bit surprised that it looked as good as it did, so I took it out for a spin. I'll get a better idea of its affect on my top speed, when I head into work, this morning.
Update: Couldn't ride in this morning, because the fog was too thick.
So far, it seems like I actually GAINED a couple of mph, with the shield in-place. In the very least, I'm able to attain speeds while sitting up, that I could only previously achieve, while fully tucked. I'm really liking this.
I know this is an old thread, but I was wondering how much less wind would you say is hitting you when riding because of this windshield? Are you still using it now? Thank you
Vinnie, i love mine!
I'm not the flexible and ad a are time trying to lay down on tank for a full tuck. I no longer need to do that anymore. I just duck my helmet below the top of windshield and I'm good.
When i installed it, my helmet kept hitting the windshield. I didn't want to scratch either so i position at a very high angle for the time being. it is currently around 80 degrees. i wanna try to get it to 45-70 degrees.
I had a harder time to position it where i wanted because the RBZ doesn't have much extra room on the bars.
Vehicle Auto part Car Motorcycle Windshield
There are a total of 6 bolts that are used to mount the windshield...
You should be able to just loosen two bolts on either the handlebar and they will come off.
I had it initially around 75-80 degrees, but i wanted to try for better airflow. It is around 60-65 tilt currently. I'm limited to position bc the RBZ bars i have on my grom only have about 2" of extra space after the controls and master cylinder reservoir gets in the way as well.
1 - 20 of 24 Posts
