A little something, something in the works
4520 Views 22 Replies 12 Participants Last post by  G19Tony
1 - 20 of 23 Posts
The blue tape makes it look great!
What is this something that you speak of...?:abnormal:
looks great. i would like to do that also
And pro taper bar cap thingers
Unless you know of another way to mount 1-1/8" bars in a 7/8" hole...
Nice! I just installed bars myself.
painting something?
The tape is so the shiny parts dont get scratched with all the fixins dangling about before they are clamped on the new bars. Not for paint, silly.
Nice. I have the adapters. I was wondering if it would work. I'm going to get the bars tomorrow. looks great! Were there any issues with cables, hitting the plastic at full lock?
Thanks. :wink:
I have that same impact!!!!! Best thing ever :)
You'll definitely have to adjust the bars upwards to keep them from hitting your leg at full lock. You can play with it until you get something acceptable. Luckily, everything works out cable length wise and such. It's a bit of a pain in the ass tightening the adapters since the bolts are so long and there are welded tabs in the way on the frame.
Vehicle Bicycle handlebar Motorcycle accessories Automotive lighting Automotive tire
Vehicle Motorcycle Automotive lighting Headlamp Motor vehicle
Vehicle Bicycle handlebar Automotive tire Tire Motorcycle accessories
You definitely feel the extra width. I only had the chance to run around the block tonight, so I'll give a full review tomorrow after I can get a decent ride it.
Blue tape mod write-up coming soon! A little hint though... It also works with red tape!
View attachment 2205 View attachment 2206 View attachment 2207
Nice write up. I figured I'd cut the bars down to the same size the bars are now.
Tony be careful with this plan. Grom grips, switch gear and levers need about 195mm of straight bar. Most bars only have about 200 mm and most minis have 185mm or less.
That's good to know. I'll look out for that. I really like how that looks. I have fat bars on my other bikes. :in love:
Agreed they look good. I had a set of fat bars all ready to go on my workbench. But once I got the Grom I decided they were going to be too wide. Most fat bars are about 800 mm which is four inches wider than stock. Too wide IMO. I would cut them down but by the time I removed 2 inches or so from each side, the grips and switches and levers would not fit.
I'm always amazed, working on motorcycles, that nothing ever works or fits without some sort of modification.
1 - 20 of 23 Posts
