1 - 6 of 6 Posts
Are those the Thai pieces?? How is the ride now?
Yep from Thailand, rides the same as before, the brake and clutch lever pivot points are not too good, had to do a little work on the brake lever to get it better, still not as good as I would like but working on that. it would work better if the master cylinder was directly above the lever. If you look on the bottom pic there is a 6mm bolt operating the cylinder, not to clever. but I have idea's floating around
1 - 6 of 6 Posts
