What was it about the Take exhaust that made you decide not to install it?I ordered some parts as I waited for delivery. Only thing I've installed were the YSS shocks. Decided against installing the Takegawa exhaust and will most-likely sell it.
The stock exhaust sounds fine to me now that I've heard it in person.What was it about the Take exhaust that made you decide not to install it?
I love the sound of the stock exhaust. Wouldn't mind making it even quieter.The stock exhaust sounds fine to me now that I've heard it in person.
I don't have a monkey, but my grom would bounce off the limiter at 76mph with those mods while tucked, on level ground. I'm 6'1 175lbs without gear. Cameron is WAY smaller/lighter than me, and the Monkey has slightly different gearing. I'm not saying you could go 78 with those mods, but I bet that he did.I still don't believe that video.
Mine with the mods putting out real power with corrected/gps tested top speeds in the low 70's mph and this bike with virtually no mods and an ecu flash is hitting almost 80 mph, calling BS.
Used to have a Yamaha Smax 155 which was water cooled and rated at 15 hp crank, full aero bodywork and it would top out in the low 70's actual speed. Speedo said high 70's though.
No.My bike has stock gearing and redline is 82 mph.
I am. Many runs to get it dialed in.With all this talk of top speeds how are you all coming up with this? Are you running a Speedo Healer to correct/accurize your speedo or just using a GPS?
Curious minds want to know...
Maybe if bombing down the side of a mountain with a tail wind. There is no way you are getting 70+mph on a stock Monkey.
Mine isn't stock. Far from it.Maybe if bombing down the side of a mountain with a tail wind. There is no way you are getting 70+mph on a stock Monkey.
Got it. I thought you said your Monkey was stock. My misunderstanding.Mine isn't stock. Far from it.
The claims of the CJR Racing video of an ecu flash on a stock head doing 78 mph is bullshit.
My 181 with all of the stuff on it only gets me to low 70's. Redline at 9,500 rpm is 82/3 mph down a hill. Did it a few days ago and it was my first time hitting rev limiter.
I am also using a speedo healer. I still use my GPS to verify speed runs.With all this talk of top speeds how are you all coming up with this? Are you running a Speedo Healer to correct/accurize your speedo or just using a GPS?
My experience with hot rod Groms, etc. is limited but I did have two pass me like I was parked on I-71 in Louisville as I headed for KY 841 and the East End Bridge. I was running about 55 and they had to be running around eighty.
I was impressed...
With the suspension done, balanced tires, it is surprisingly stable.Got it. I thought you said your Monkey was stock. My misunderstanding.
Man, I can't imagine doing 80 on this little thing....that is crazy!
You said it only gets you to low 70's, then say you hit 82/83. Nobody claimed he was cruising straight up on level ground. I'm sure he was tucked in tight, probably on a downhill slope. Still to hit a maximum speed of 78 is impressive, and you should not insult CJR @jonesn by implying he is falsifying his videos. Especially if you don't have any proof. Do you mind sharing your height and weight?Mine isn't stock. Far from it.
The claims of the CJR Racing video of an ecu flash on a stock head doing 78 mph is BS.
Level ground with no wind is low 70's.You said it only gets you to low 70's, then say you hit 82/83. Nobody claimed he was cruising straight up on level ground. I'm sure he was tucked in tight, probably on a downhill slope. Still to hit a maximum speed of 78 is impressive, and you should not insult CJR @jonesn by implying he is falsifying his videos. Especially if you don't have any proof. Do you mind sharing your height and weight?
I would love to ride down the mountain with you, lol. I'm about 4 hrs away from anything that even favors a mountain. My 83mph was down a hill, not a steep hill though. One day I am going to find a steep hill and shoot for 88mph, then go back in time and warn myself to slow down before I get a ticket. Do I need a Delorian to do that? LolLevel ground with no wind is low 70's.
My bike stock would do high 70's down the nearby mountain. That isn't a top speed, IMO.
DeLorean? No. Flux Capacitor, Yes.I would love to ride down the mountain with you, lol. I'm about 4 hrs away from anything that even favors a mountain. My 83mph was down a hill, not a steep hill though. One day I am going to find a steep hill and shoot for 88mph, then go back in time and warn myself to slow down before I get a ticket. Do I need a Delorian to do that? Lol
