1 - 20 of 41 Posts
The LL552 relay does work with the Thai spec turns. Flasher location is behind the head lamp. Auto part Vehicle Car Subcompact car
Vehicle Car Auto part Automotive exterior Steering wheel
Automotive exterior Auto part Bumper Automotive design Vehicle
Light Automotive lighting Tire Automotive tire Auto part
The blue connector is for the turn signal. It has 3 wires and the thai blinkers have only 2.
Good to know thanks.
And that is the stock flasher shown in the pictures right?
good to hear this worked out. I didn't have a chance to try it prior to my Grom being stolen.
Whats a 552 flasher and whats it for? I dont get it.
Make sure the wires connected for the fronts are the solid colors and rear are with lines and if this still doesn't work you may have bought led blinkers with non built in resistors, then place an in line resistor for each positive line for each individual blinkers.
Good luck!
I put the EL12 in for rear and front leds now they dont flash any ideas?
can't get mine to work with fronts and rears, just rears we're working fine with the 552, added the fronts and now I can't get them to blink, tried 552, el12, 100 ohm resistors on all 4 positives, wires are correct, they all light up when I hit the turn signal just don't blink, any ideas?
1 - 20 of 41 Posts
