1 - 4 of 4 Posts
Yes that is right, for a limited time only we have an end of season sale with35% off the fully adjustable TYGA Performance CNC rear sets. This makes them around 250 US dollars a set at today's exchange rates.
With all major components desgned specifically for the MSX125 Grom in mind, this rear set kit is the best on the market. Designed in-house by TYGA Performance using the latest CAD/CAM software, these tough CNC machine-made step kits are made from top quality, aircraft grade aluminium and utilise TYGA's unique and elegant system to provide ten different foot peg positions. See fitting instructions for details. The kit features levers moving on ball bearings to give precise and smooth movement. In addition to the technical specifications, emphasis has also been given to make the steps as uncluttered as possible with the rear master cylinder hidden from view and no unsightly unused holes on view etc. The kit comes complete, ready to bolt on with stainless steel fasteners and carbon heel guards. With individualism in mind, there is a choice of ten colour combinations available and all components are available as replacement or separate items. Be sure to order the correct colour combination. Some photos below are for reference and show different colours to this product.
Ordered on Monday arrived today and installed / adjusted two hours later. Awesome product great looks and for the most part an easy install.
Couple of things to note. You loose the rear brake light switch. And you have to enlarge the hole for the pin on the brake cylinder to the foot peg. Other than that they bolt right up and look awesome. Great vendor super quick shipping. Will buying more parts I'm sure!
1 - 4 of 4 Posts
