1 - 5 of 5 Posts
Just installed the new low profile LED light bar kit. Technically it does reduce your suspension travel clearance by about 1", so not ideal for off-roading and stunts, but really helps with the poor OE low-light output on the 2nd gen Grom. There is a thick foam pad on the underside that helps to protect the front fender if it does bottom out.
I don't have an issue with light output on my 2017 SF. Thought I did when I got the bike, but once I aimed the light properly it was WAY better. Even had to readjust the light a few times as I did suspension mods, due to the bike sitting differently.
Does this one bolt into the stock light's adjuster bolt hole?
Yes, it bolts in with a replacement headlight adjustment bolt. It actually even retains the headlight adjustment function.
1 - 5 of 5 Posts
