Checking in...
I took note I needed to keep an eye on the rear tire tread the other day as I noticed the center tread getting thin on the White SP. When I recently checked more closely, I discovered my tread indicators on the Power Pure SC weren't there, ...long gone in fact. When it starts to get worn, that last bit of tread really goes fast!
So I was really wanting to take the White SP out for a run before it got dark the day before yesterday so rather than spoon the tire myself, which takes me a while, I ran the wheel up to the dealer right before closing and they swapped on a new power Pure SC 140 I brought with me in no time. And they were kind enough to swap in an aluminum valve stem I brought too. It took maybe 15 minutes and I left there quite smug as I didn't even break a sweat.
Got home, put the wheel back on and as I was tightening the axel nut I detected a disturbance in the force. The axel nut was giving me trouble. I noticed it was hard to take off but didn't stop to think why because I was in such a hurry to get on the road before dark. But it sure wasn't going back on the way it should, something felt wrong.
I'm such a doofus. Too many 2 minute quick chain adjustments acting like I was the Ace in a pit crew came back to bite me in the ass. My axel threads were all boogered up, but I didn't get mad. I knew who was to blame. From now on I'll take a beat to grab the torque wrench. I've done this procedure so many countless times smiling because of the convenience of the aftermarket chain adjusters and spooled stand combination. Luckily I had another axel bolt in my spare part stock reserves. Now, finally, it's off to the races!
But before I grabbed my helmet I took a gander at my front tire tread. It's remarkable it has 8000 miles on it and plenty of tread left.
No, it didn't.
To clarify, when I actually took the time to find the tread indicators on the OEM IRC front tire I realized they weren't located in the center cut groove, which was still looking great. They were just off to the sides of it in the side sips. They were there - but indicating the jig was up. Then I noticed the tread wear on both sides of the center cut line and realized there should be more sips along it, but some had been completely worn away.
Oh hell, forget the twilight ride, I'm changing that front tire right now.
That was fun.
Lots of sweating and cursing, ...had to be done though, and I got an aluminum valve stem put in. With that done and my ride window for the night closed I turned my attention to the chain. Yep, of course I found inconsistencies in slack tension as I rotated the tire. Off with the rear wheel again, new sealed chain installed. Sprockets were in pretty good shape with little wear showing (I swapped OEM replacement sprockets in around 4000 miles ago at the last rear tire and chain change.)
EDIT: And swapped in a new OEM sprocket pair again anyway, they're so cheap I figured might as well.
All that was the day before yesterday. Just got back in from a twilight ride and everything feels good. Really good. Sharp as a tack in fact. Switching over between quick left and right tight sweeping curves has a really good feel now. I never pontificated how nice the Ohlins suspension is and I'm not going to now other than to say... pure bliss.
Should have changed those tires sooner I guess. ...meh, Live and Learn.
So what have I learned? OEM rear tires last me about 4000 miles. OEM chains last me about 4000 miles. After market rear tires last me about 4000 miles. After market sealed chains last me about 4000 miles. So now I know.
I do tend to ride the 22 white SP in a "spirited" fashion, some might even call harsh. Not like the lollygagging grocery runs on the Trail125, ...no.
While the front OEM tire seemed to last a lot longer than I ever expected, I'm going to remain better vigilant of those tread wear indicators from now on and see how long the new PP SC front tire lasts next time 4000 miles comes around 😉
