81 - 100 of 128 Posts
So it has not got any better with mileage or an oil change to remove the factory oil?
have you tried using your heel instead? lightly tap with your heel from 2nd.
I don't have my Grom yet. It will arrive in Feb. but I have been watching Youtube videos...
Something worth trying I guess. lol.
That black looks nice! I wish Honda would have went with the silver on the OG instead of the gold. I'm now jealous of your white and black!
Discussion Starter · #83 · (Edited)
Some pics of winter restlessness
I wanted to add a GPS to my daily GROM commuter so I picked up some handle bar clamps that would accommodate a powered GPS mount. While I think putting a GPS on a mini bike is a little nutty, I've found myself in many situations where I wish I was on one of my larger bikes that has one. I've never really used GPS on my bikes primarily as a navigation tool.
I often abscond on little mini adventures throughout my days in between chores as it's difficult to find the time to ride as often as I'd like. So when I have to pick up food at a certain time, or need to appear somewhere for an appointment, I find it extremely convenient to set that destination point in the GPS and then just go ride wherever I want in the whimsical manner I find most enjoyable at the time. By keeping an eye on the running "time to destination" displayed on the GPS, it insures I never venture too far out and arrive late.
Another reason is when I get that dreaded call and need to appear somewhere "RIGHT NOW," I use it to inform them what time I can get there. This comes in handy when I'm in BFE in the middle of no where and haven't a clue the shortest route to take to arrive quickly. You know, when the back roads aren't marked and you're reduced to looking at the sun to figure out what general direction you need to head to get nearer civilization? 😬
I doubt I'll want a GPS on the SP but picked up the appropriate handle bar clamp for it in case I decide to add one down the road
Motor vehicle Automotive tire Automotive design Plant Vehicle
I began by installing a Ram Ball on the black commuter Grom handle bar mount
Fuel tank Motorcycle Automotive tire Motor vehicle Automotive lighting
Then I wired it so it wouldn't need to rely on the GPS internal battery power and it would cut power to the mount when the key is turned off so if I were to leave the GPS on the bike for days it wouldn't put a drain on the bike battery trying to re-charge the GPS internal battery pack
Vehicle Motor vehicle Automotive tire Automotive design Motorcycle accessories
Discussion Starter · #85 ·
It presents a nice in your face view right under the LCD display. I prefer my GPS mounts centered and avoid mounting them to one side or the other, because I'm weird that way
Light Product Gadget Communication Device Material property
Tire Wheel Bicycle Land vehicle Vehicle
Vehicle Automotive tire Motorcycle Motor vehicle Automotive design
Discussion Starter · #86 · (Edited)
A few other things to note after installing brass swing arm bushings, an Ohlins front suspension replacement along with a Nitron rear, I added some fenda extenda's for inclement weather
Front
Tire Wheel Automotive lighting Vehicle Automotive tire
and Rear
Tire Wheel Vehicle Fuel tank Automotive tire
Discussion Starter · #87 · (Edited)
I wanted to keep this bike dull, boring, nothing to see here, and got rid of the glossy black side panels and triangle covers
Vehicle Fuel tank Motor vehicle Automotive tire Automotive lighting
Tire Wheel Land vehicle Vehicle Fuel tank
The only bit of glossy black flashiness I will address next will be the outer head light shroud. That will be another SP part I swap in later.
And I'm on the fence with the eye catchy seat, but I will say the fit and finish is exemplary. The OEM seat has more cushiness and more of the blandness I want with this commuter purposed bike but I haven't road tested the new one as yet.
The idea to make this bike less attractive is simply for peace of mind and so I might increase the odds of still finding it parked wherever I've left it. The SP seems to attract a lot of attention and it makes me nervous about leaving it unattended for any length of time. :rolleyes:
Discussion Starter · #89 ·
Quick update
After 650 miles put on the black commuter Grom I went back to the OEM seat. The aftermarket seat I tried felt wooden and squeaks. While it looked nice there were no benefits to speak of. The 22 stock seat is an absolute gem there's no denying it. The first 30 mile ride with the stock seat put back on had me smiling the whole time. Lesson learned.
The GPS mount is working nicely with the solid attachment, no vibration in the display.
The OEM exhaust allows me to go faster than I should with out attracting attention in dense areas, I'm loving it. I've noticed I'm tending to wring out rpm's well into redline a lot more often than the SP which has a much louder exhaust, ...shouldn't be hurting anything.
The Fenda Extenda's are doing their job and lessening cleanups noticeably.
The suspension upgrades are all class. The bike remains aces for my intended purposes.
One of the first things I did was replace the chain with a sealed U-Ring chain for convenience. And install a plug-in gizmo from TST so the brake light does a triple quick flash when brakes are applied for the sake of conspicuousness. Nothing exciting about those changes, but worth it to me.
If anything odd should arise outside of what I've already shared with the SP in this thread as the new commuter accumulates lots of miles - I'll report here.
Great thread and great looking SP!
I agree about being able to wring it out without making a loud noise is one of the biggest advantages of riding the Grom in the populated areas.
A little more power and top speed would be nice but the loudness that comes with more power is not what I want.
2014 Grom
Your Garmin looks not bad at all, but I'd swap it out for a radar detector if it was me. I've eaten 3 speeding tickets on my grom so far :rolleyes:
  • Haha
Reactions: SlimJim and Dav101
Discussion Starter · #92 ·
Picked up another SP for a Yoshi dual exhaust. I bought it during a bad rain storm. The dealer didn't want to run it in the weather and gave me an option of having gas put in it or not. I took advantage and said "no thanks." After they uncrated it, installed mirrors and battery, I trailered it home and dried it off. To this day it hasn't been turned over yet. When it gets warmer I'm going to get some gas ...and hope it starts - LOL
Dressed it in some parts and plastics over the weekend that I've been hoarding for some time. Pretty sure I'll never be able to justify this one but I just had to have one more piece of 3rd generation "Pocket Candy."
I went in the opposite direction of my black commuter Grom - Racer Boy! :ROFLMAO:
and... picture dump:
Wheel Tire Fuel tank Motorcycle Automotive lighting
Tire Wheel Fuel tank Automotive lighting Vehicle brake
Automotive tire Synthetic rubber Bumper Automotive parking light Automotive exterior
Land vehicle Tire Fuel tank Plant Vehicle
Tire Wheel Plant Automotive tire Automotive lighting
Wheel Tire Fuel tank Vehicle Motorcycle
Land vehicle Vehicle Motorcycle Automotive lighting Automotive tire
Wheel Tire Plant Automotive lighting Automotive tire
I'm so ready for this summer
Discussion Starter · #94 ·
Three?! Omg.
I am hoping Honda will make 150-200cc Grom next. Price it $5000. I would still buy one. Wouldn't you?
As an enthusiast, sure. But a factory Grom with a larger displacement might break something that's not broken. What has made the Grom so wildly popular? It's an unassuming small bike that is well known for training new beginner riders and yet still appeals to so many other groups unilaterally across the board. Can you even find a Grom review with out the word "fun" in it? Ever hear the expression "leave them wanting more?"
What I love about the latest generation Grom is it does just enough for such a small bike. Personally, I think increasing the displacement leads to higher expectations. When I'm riding it I'm trying to make the best of what it's got. As an experienced rider, I like to do more with less. That's what makes it fun to me. It would be so bloody easy for me to slap on an intake, cam, and flash but where would that lead me? Might as well get on one of my 300's albeit with out such a small form factor.
Obviously I'm biased though. It's the perfect doodlebug for my riding environment.
I enjoy riding Grom as is also.
Even more so than my previous bikes which were bigger (300, 400, 700 cc).
I embrace 95% of Grom for what it is.
The only thing I wish Grom had is harder and longer pulling 2nd gear.
1st gear is meh. OK. it is the 1st gear so I shift out of it almost as soon as the bike is moving.
3rd and 4th gears pull very good.
I love the 4th gear. That's where I usually live. IIRC, 25-50 mph. I feel good in 4th gear.
I use the 5th gear when I need the top speed of 60+ mph to keep up with the traffic. Or when I know I will be behind the traffic and I won't be going anywhere. Just cruise along 50+ mph.
But the 2nd gear in my previous cars and bikes was where the most acceleration happened. Often up to 60 mph.
The most excellent pull happens in the 2nd gear in all my previous gas powered vehicles.
But on the Grom, 2nd gear feels flat. Out of fume. No gut.
That's probably why I was hoping for a bigger engine like 150cc.
Around the world 125cc is the magical legal cut off for the beginner licensing. And I am not saying Honda should make all Groms with 150cc. Knowing Honda, they will probably make 130cc Grom and call it a Grom Spec R, IF they decided to give it a bigger engine option model. I would still be all over it. And put the deposit down for the first one at the dealer.
I love my 2022 Grom SP so much. I know there is no perfect bike but the Grom is 95% perfect for me. I am just hoping for the last 5%. LOL. I don't plan to do any power mods. I like OEM and 121 mpg ( and it keeps on improving).
im actually looking forward to some mods to mine
intake
Exhaust
Cam
Tune
looks to be perfect mods to make the bike do whats needed
i thought about a high comp piston but for the extra ifeel the other mods are a perfect idea
but if you think about it
Suzuki make a 125 dohc 6speed with 15hp
now that sounds about perfect to me in such a small bike
look at the stuff ktm does
it would be nice to see a supergrom
more power and decent suspension
lets face it , at production stages , its not that more expensive to have decent suspension
power though the issue is emissions and noise which is wher the manufacturers have to comply but if suzuki can do it then theres nothing stopping honda
Discussion Starter · #97 ·
intake
Exhaust
Cam
Tune
I think those mods would be perfect for getting you just a little bit more.
As I said though for me, I really like the Grom as it is and immensely enjoy trying to do more with less in the area I ride.
Making it do what's needed with stock power is precisely the challenge that keeps me so entertained with it as opposed to pushing it too far towards something it's not. It's taken me years to recognize and avoid the trap of always wanting just a little bit more in that regard with these diminutive bikes which has made me simply appreciate it for what it is.
I looked up that Suzuki and wow! That would be quite a speedy riot!
if you look at the dyno graphs
you can see a stock bike just dies midway due to the restrictions
when you look at the graph with the intake , exh , cam
you can see its a nice curve and exactly how it should be without any undue stress
What it does do is make the bike easier to ride with less stress
and in turn a whole lot more enjoyable
and remember you dont have to wind it to redline all the time
Discussion Starter · #99 ·
I think you're on to something here :unsure: LOL
If power mods had no increase in the noise level, I would have done them already.
