1 - 7 of 7 Posts
2022 Grom RR Oil Coolers available now.
If you need some Heat Reduction for your 2022 Grom RR, 3 Row and 5 Row Oil Coolers
3 Row Cooler
5 Row Cooler
Font Auto part Tool Circle Electric blue
Tool Font Auto part Technology Circle
Automotive tire White Automotive lighting Light Motor vehicle
IAT sensor for inlet air temp
Thanks for the reply.
What doe the IAT sensor have to do with the oil cooler?
Does the stock IAT cable need to be replaced (length, routing?) as a result of the oil cooler install?
Got it:
NOTE: REQUIRES REMOVAL OF STOCK AIR BOX
so the cable replaces the stock intake air temp cable. (I assume)
yes gives you slack to allow for new position of sensor , witch will be located on the new oil cooler bracket.
also note may need to use side style air intake, not sure it will fit with the billet style intake.
1 - 7 of 7 Posts
