2020 Honda Monkey (non-ABS) highly modded with broken engine
6495 Views 39 Replies 13 Participants Last post by  jtacoma.jc
Heavily modified 2020 Honda Monkey with the blown Takegawa 181cc 4 valve and 5 speed.
Located in Las Vegas, NV.
50 state bike.
Approximately 4,000 miles total.
Includes stock and modded parts in the price with a reasonable offer.
$3500 for everything.
YSS front suspension internals
YSS Reservoir Shocks with rebound, height, and preload adjusters
Takegawa Aluminum Bars
Magura Hymec Radial Hydraulic clutch conversion
Magura Radial brake master cylinder
Opmid Dash
Spiegler Front Brake line
Chimera Brembo Caliper brackets front and rear
Brembo Calipers front and rear
Chimera front axle and swingarm pivot
Kitaco rear axle adjusters and axle
Over Racing Rear Sets
K-Factory Stainless steel exhaust, removed restrictions
A-Racer RC Mini 5
A-Racer Wideband AFR
A-Racer wire splitter
Takegawa front fender lowering bracket(best quality)
MNNTHBX fender eliminator
Takegawa Oil Catch Can kit
Takegawa-
10/10D cam(New in box)
15/15D in the engine
181cc 4 valve 5 axis ported head(may still be good but don't count on it)
5 speed
Crankshaft support bearing
HD oil pump
Slipper clutch
Clutch cover
Twin oil coolers
HD Cam Chain Tensioner arm
Grom Fatherz manual cam chain tensioner
Derazer Seat plus stock
34mm throttle body
Lithium battery upgrade
Honda Forza 300 fuel injector
Honda Forza 300 fuel line
DynoJet Power Vision 3 with stock ECU
Stock gauges
Stock handlebars
Stock clutch cover and clutch
Stock shocks
Stock license plate bracket
Aluminum bar end mirrors(not cheap ones)
Chimera billet sprocket carrier
Spare Billet shifter for stock foot controls
Spare gaskets for clutch cover and stator cover
RK MRU chain is new
Aluminum rear sprocket is new
16t front sprocket new not installed
Many thousands of dollars invested. If I don't get the asking price I'll part it out to get the money back out of it.
Probably forgetting a few things but it all goes with the bike.
Never registered it. Have all dealer paperwork.
21 - 40 of 40 Posts
@Chillis , what do you think of that Chimera drive carrier?
Considering picking one up.
How much lighter than stock?
Another option? or is that just for Z125:
That drive is heavier though:
"Grom Fatherz Hyper Cush Drive hub. Bling to the max! Unfortunately, the Hyper Hub weighs about 48 grams more than the stock hub...lol. I don’t care. It is likely stronger, not that you would probably ever break the stock hub. It is a nice piece. Beautiful."
Your bike is a masterpiece!
So are you keeping it? I really hope so... she was coming together so well!
If somebody offers up the cash I'll sell it. Otherwise, it is paid for so it is only taking up space in the garage until it gets a new engine.
I never would have upgraded the hub if I didn't break a stud on my stock hub.
The stock hub is very light.
Chimera uses screws which are replaceable to hold on the sprocket instead of pressed in studs like stock. I prefer this over the stock arrangement.
I haven't sold it. Not sure I am going to.
If you are going to build a new motor for it.....
Billet cases are now available. You have the choice of grom style cylinders and heads or yamaha mio/bws cylinders and heads.
90825
90826
90827
  • Love
Reactions: 3
That is awesome. Where from and why use different cylinder/head?
The main vendor is BikeEmpire in Thailand. Look at their page on facebook. There are several other vendors and resellers in Asia.
The yamaha cylinders and head have a lot more parts and kits on the market for >200cc. The BikeEmpire shop bike is 350cc.
EXPENSIVE $2000
EXPENSIVE $2000
That's for the z50. The Grom/monkey ones are made by BMP Modding and cost 1200usd
Is there a link? I'm not finding anything.
If someone hasn't claimed ill call dibs on the down fender kit. But for the time being which kit is that? I haven't seen it before.
I'm not selling off parts. Still undecided about selling the whole bike.
Fender kit is from Takegawa. After researching all of the designs it is the most robust/well thought out design.
@mongerrr what combination would you choose for the case/top end for reliability while still able to make power?
I look for the BWS 125 aftermarket parts but it seems minimal are in the US and I can't find much searching on the phone for other country's goodies either.
Pull your engine apart first. If your head is still good, then build up a motor with that head. If its trashed, then consider a neo for max reliability or a yamaha bws/zuma zuma if you want big torque.
Those billet BMP cases look sweet
@mongerrr
In the USA, they are sold as Zuma 125's
Drowsports sells a 200cc big bore thats also converts it from air cooled to water cooled
A guy here in Hawaii has a
2020 OEM Honda Grom Engine for sale $900, 500 miles
90879
Tire Wheel Vehicle Automotive lighting Automotive tire
90880
View attachment 90879 View attachment 90879 View attachment 90879 View attachment 90880
That's a Monkey engine. Sight glass and silver.
I'm going to do another build if I keep the bike.
21 - 40 of 40 Posts
