1 - 6 of 6 Posts
Brand new 2020 GROM, Just ordered a TOCE exhaust for the noise to alert drivers.
I do not care about adding power or speed.
The exhaust is purely for my safety. Now in regards to my motors safety.
After installing and resetting the ECU this im aware is highly recommended so i will do that first thing.
Do i need the power commander or will the ecu reset adjust accordingly.
Money isn't an issue, if I need it to run how it is supposed to like brand new ill buy it, that being said i don't care about performance gains.
The bike is amazing as is im only concerned with performance loss/leaning out/damaging the motor.
P.S im not doing an airbox i like the bike as is just needed more sound if im not concered with increasing power can i safely assume it will still ride great and fast and be healthy? Would love to know this before i install it as my friend already offered to buy it off me if it will damage the motor and do it to his as a guinea pig.
**TLDR**after installing the full TOCE exhaust on a 2020 grom, then resetting the ecu, will i need a power commander to keep it running normal and safe. Its a brand new bike and would like it to ride just the way it always has just way louder. Thoughts?
I believe you will be fine. If you are concerned about it an ecu flash from Cameron Jones is much cheaper than a pc3 and will richen up the overly lean stock map. Also makes a little HP which is never a bad thing.
Reactions: 50-50
Awesome Thank you for responding!
Just looked around the site and sent an email out on location and the exhaust i have what lvl do you recommend im sure he will tell me but curiouse to hear what others have to say a v1 is the best bet probably if i dont plan on doing airbox and all the other stuff id assume.
Go with whatever he recommends, make sure he knows what octane you want to run. I have had no problems with his flashes at all. Great product.
Reactions: 50-50
1 - 6 of 6 Posts
