1 - 6 of 6 Posts
I'm looking to remove the front fender from my grom and plan on running it like that. From those of you who have done that, how did you handle the dangling brake line? I'd like to not go the zip tie route to the forks but if that's the easiest solution I suppose I would.
Thanks! are you talking OEM or do you have a link for a good aftermarket fitting?
I also did the monkey guards recently along with "half" the OEM fender, but before that was an option, I used the bolt hole for the fender to attach my brake line,
you can kinda see in the pic below.
89802
My Current front fender setup:
89803
1 - 6 of 6 Posts
